2 members (55shaker, 1 invisible),
55
Mod | | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 152 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 152 | Hey guys, I need some help figuring out which carb I have vs. which one I should have. When I purchased my '59 38 with 235, the PO said he had installed a rebuilt carb and had installed an aftermarket breather (dinky little chrome thing) because he couldn't get the oil bath cleaner to fit the new carb. After finally getting around to checking it, I found the reason: The installed carb requires a breather with a 2 5/8" opening, while the oil bath breather has a 2 1/4" opening. Do I have the wrong carb. or did he give me the wrong oil bath breather? The carb has the following lettering and numbers on it: Front = Rochester Monojet made in USA. Top = 12. Side = 7043021 270 2 (and an illegible number). Does anyone have any ideas whats going on here?
Oldbolter 1959 Apache 3800 dually flat bed/dump with 261 1956 3800 dually flat bed/dump with 235 1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | monojet didn't come on a 59, a rodchester model B would be the carb.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The Monojet is a good carb. If you are not concernd about originality I would find a late 60's or 70's dry type air filter. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2009 Posts: 152 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 152 | Thanks for the help everyone. Now I know this isn't the original carb. Wrenchbender, I plan to look for a more suitable air filter for the monojet, at least for short term use. Should I be concerned about the monojet being too large for the 235? My Apache drinks gas at an alarming rate.
| | | | | Joined: Feb 2000 Posts: 5,208 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,208 | Not at all to big, I am running two of them on a 250! You can lower the float a bit which will lean it out some of need be.
Joe | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | I ran one for a while on my 261, ran better than the B.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It should get better mileage then a model B. Like Joe says check the float level. Make sure the metering rod link did not fall out of the hole. This is a small curved rod that connects the throttle shaft to the metering rod holder. They are known to fall out on the early models & cause a rich mixture. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2009 Posts: 152 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 152 | Thanks. I will open up the carb and check the float and metering rod holder.
