4 members (66flea, Eisenholtz, Otto Skorzeny, Shardean), 70 guests, and 1 robot.
Topics128,023
Posts1,055,367
Members48,420
#780951 09/15/2011 1:38 PM
As I continue to wire my '51 3100 I've installed backup lights from a '50 passenger car. Since these trucks didn't come with backup lights what have others used as a backup light switch and how have you mounted and wired it? Thanks
It never costs more to ask and it never costs more to think big.
Is your truck a 3 speed (on the column) or a 4 speed (on the floor)?
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
-Unknown-
Here is a good discussion regarding the "on the floor switch".
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=722163&page=1
-Unknown-
Truck is a 3 speed on the column.
Here are the ways I have heard that other bolters have done it for a 3 speed on the column.
1) Put in a manual toggle switch under the dash. There is several discussions here on that topic.
2) I talked to one bolter that used a Chevy TF switch. I believe he mounted it on the fire wall and it switched off the transmission linkage near the steering column. In a test, I actually duplicated this using a modified brake light switch.
The method I finally settled on, which was available in the 1950's but not widely used, was a position sensing switch (an inductive sensor). I mounted it behind the dash on the brace above the steering cloumn. So each time I place my truck in reverse The switch senses the postion and turns on the backup lights.
Dale
-Unknown-
Ex Hall Monitor
Ex Hall Monitor
The simplest is to put a switch under the dash. When backup lights were first put on, that's how they were switched. Connect the wire to any hot wire and run it to the switch then the light. Make sure the light is grounded. Mine is connected to the switched side of the ignition switch so that it's dead any time the key is off to prevent an accidental drained battery.
OLTrucks
Unregistered
OLTrucks
Unregistered
A good buddy of mine (Jerry Rivers)has one from a car he uses on his 1948 suburban, It mounts on the three speed shift box under the hood, It sure looks nice and stock and works every time. Some might of seen it at the reunion this last weekend. I would have to see if I can get a photo of it so all can see.
Mike
#781130 09/16/2011 1:39 AM
diagram of TF setup for column shift
Thanks Bill. I wondered how it was setup under the dash. I had only see it installed under the hood.
-Unknown-
