| | | Forums66 Topics128,070 Posts1,055,900 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 89 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 89 | looking for a fairly cheap truck cover for the 3100 that'll hold up thru a winter (truck's body work is an ongoing process as my truck is a regular driver).
'search' didn't produce much.
it ain't YOURS 'till it ain't stock!
1951 chevy 3100
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I'm not aware of any specifically built for the AD truck but you should be able to use almost any of the ones built for full-size trucks. A better option might be to use tarps. | | | | | Joined: Apr 2011 Posts: 107 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 107 | I got mine from Brothers Trucks. They are made to fit for the different truck years. I bought the bigger dollar one since mine spends a lot of time outdoors but they for sure had some in the 150.00 range. Can't speak for those but the one I grabbed fit my truck perfectly and has been bomb proof.
| | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 |
Got mine from LMC and it was made to fit my truck year, which it did. Some folks here have purchased "made to fit" from LMC and had different results.
Dale
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. -Unknown-
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There are ready-made covers available for A-D pickup trucks (as described above). What model/size truck are you referring to? Search for truck coverhttp://www.classicparts.com/default.asphttp://www.oldchevytrucks.com/cart/index.asp?sdes=truck%20coverCalifornia Car Covers sells a variety of styles/qualities covers for just about any model/year car/truck body. They can custom modify for any types of add-on lights, mirrors, bed-side tire carriers, and antennae. They range (widely) in prices but are they are more expensive than the covers above. | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Yes for Calif car covers. I have one for my truck.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Jul 2010 Posts: 89 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 89 | 1/2 ton 3100 1951
anybody ever try a generic cover for say a s-10 ext cab or maybe a ranger extra cab (also cab and a half)
kinda caught me off guard hearing a suggestion for a full sized pickup cover - has anyone tried this -one truck work better than another?
been useing a poly tarp BUT would like something that breathes well under the poly tarp for the long cold winter - (yanking the motor this winter to rebuild).
1951 chevy 3100
| | | | | Joined: Aug 2007 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 37 | I bought one from LMC that lasted out in the wind sun and other weather we get here for 3 winters. Once it got its first hole the wind tore it apart in pretty short order. | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Another issue to consider is the bed area. If you use a full cover and the truck is not under a hard roof or tarp tent, how do you prevent the truck cover to not sag down into the bed and start collecting rain water?
I made a quick install frame made out of pvc pipe which I first install into the bed, with it running down the middle. Then I install the cover. The frame helps support the cover into a somewhat Teepee shape. So if it rains, the water runs off the sides instead of collecting in the bed.
Now that the truck is stored under a tarp tent, I don't use the cover so much and especially the cover support.
| | | | | Joined: Jul 2010 Posts: 89 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 89 | Have a bent wood stepstool and with the rounded top, placed against the tailgate, the tarp streched with bungiecords, holds the snow load just fine.
just would like to get it to breath a little. esp on the hood and roof where the tarp is getting frozen to the truck cause it wont dry out under there.
THOUGHTS???????????????
1951 chevy 3100
