3 members (1955 1 Series, Dave Richard, Buckeye998), 321 guests, and 5 robots.
Topics128,156
Posts1,057,021
Members48,460
Hello all,
I just purchased a second 52 Chevy 3100 series. The vacum wiper motor was replaced with an electric one. However, it does not work well. It turns on but the blades only go about 3 to 4 inches across the windshield and then when I turn them off they stay up on the windshield. Any thoughts on how to fix this? It makes driving in the rain a challange :-).
I have thought about taking the original arm braket off the old one and putting onto the new one to see if that would help.
Thanks in advance for the help!
Take care,
Steven
No one can drive us crazy unless we give them the keys.
I'm running the original arms with the new motor, that may solve your problem. I still have a minor problem with the stop position on the passenger side though.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
All,
Sorry for the confusion but, regarding the original arm bracket, I was talking about the bar that is welded to the vacuum motor itself. The arms attached to the original wipers are still in place.
Take care,
Steven
Leo Offline
Moderator
Moderator
You have the exact same problem as Weeds who drove in a rain storm in Kansas City last weekend. I also installed the electric motor, using the original arms. I drilled a new hole half an inch short of where the long arm (right side) goes into the wiper. I carefully pounded back the peined end and moved it to the new hole. (The problem, in my opinion is the electric wiper unit, if you hold it beside the original vacuum unit, you will see that the arms are a bit longer)
Leo,
where did you get your electric motor. I ask because I understand that there are two models, one which interferes with the space the radio takes up.
Fred
1951 1 Ton Completed
Thanks 1953 Panel, The gentleman I purchased the truck from sent the original vacuum motor, I will pull the electric one and take a look at it.
Take care,
Steven
