| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78063 05/26/2007 10:29 PM | Joined: May 2007 Posts: 6 Junior Member | | Junior Member Joined: May 2007 Posts: 6 | Are there any other carbs besides a weber based Carter or Holley that will fit on the 1 to 2 barrel adapter??? | | |
#78064 05/27/2007 4:36 PM | Joined: Apr 2003 Posts: 67 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 67 | Hi, where did you find the one to two barrel adapter ?
I have a GMC 270, thinking the same.
Royzell | | |
#78065 05/27/2007 4:37 PM | Joined: Apr 2003 Posts: 67 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 67 | Hi, where did you find the one to two barrel adapter ?
Royzell | | |
#78066 05/27/2007 5:13 PM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | There are the H/W adapters and also the three bolt Stromberg 97 style also, if not more out there. I believe Speedway motors has the 97 type. | | |
#78067 05/27/2007 9:02 PM | Joined: May 2007 Posts: 6 Junior Member | | Junior Member Joined: May 2007 Posts: 6 | royzell I got my adapter for Landon's Stovebolt. Tom the owners a great guy he really helped me out keeping parts in my budget. You should check him out. | | |
