2 members (Don88, Nick in Manitou), 111 guests, and 2 robots.
Topics128,162
Posts1,056,936
Members48,458
#780621 09/14/2011 2:29 AM
sps
Offline
How much and what weight should I use?
Leo Offline
Moderator
Moderator
Mine is full of grease.
You might try John Deere Corn Head Grease. Good stuff for a steering box, and won't leak out like the 90 wt gear lube.
Some specs from Deere:
Special-Purpose Corn Head Grease (AN102562, AH80490, TY24428)
Applications
· Formulated for John Deere corn head and other slow-speed gear cases
· Extra-soft grade of lubricating grease, required for row-unit gear cases of John Deere corn heads
· -30 to 330°F (-34 to 165°C)
Kurt
and self leveling....
GMC: Get More Cash...
1958 GMC
My Webshots photos
Its been talked about many times. The John Deere corn head grease has been the consensus many times.
Corn head grease is a 00 grade, which is self leveling. It flows back in on itself as it is used, very much like a supper thick gear oil. Any brand of grease will work if its NLGI 00 or NLGI 000 grade grease. Normal chassis grease will be pushed to the corners and stay there.
As for how much, enough to cover the gears in the box. My '41 gear box holds almost one whole tube of grease, your might be more since its newer and probably bigger. To much grease can be pushed out the input shaft and up the steering column tube.
John Deere grease can be bought online or at any dealer ship. The lawn mower dealers may have to order it in, and the price is around $3.00 a tube.
Joe
