8 members (Robert Crandall, kades51, Hotrod Lincoln, jay d, Hanks custodian, Rusty Heaps, Uncles51, 1 invisible), 124 guests, and 2 robots.
Topics128,041
Posts1,055,480
Members48,424
#779799 09/11/2011 1:55 PM
1 Offline
I ran into trouble yesterday, got my panel turned around with engine facing garage door. I am now ready to lift cab off frane. One last thing to remove is steering column, pulled steering wheel off and figured all I have to do is remove 4 bolts off of steering box and pull steering column out. I can't seperate the gears they seem to screw apart but something is locking it in at the end of worm gear? Does anyone know the answer to tis please!!
1 Offline
OK, figured it out. I took the end tension nut out and seen what's holding shaft in. It has a bearing with a flanged washer holding it on. Don't want to mess with that. Sooo I will remove the whole steering box along with shaft as one assembly.
1 Offline
To remove the whole assembly. First of all hold wheels in straight line, mark arm lever on housing at angle. There are 4 bolts and one driver side steering linkage. pull cotter pin out of linkage attached to steering box arm. use largest flat head screw driver availble and unscrew linkage knuckle from ball. Kinda like a hip joint, once loose enough it will pop off. 3/4 inch six sided wrenches and sockets are you best choice. remove two from side of frame using inside of frame as wrench holder. Renove top bolt using side of frame as holder of wrench. last bolt is underneath front of steering box I used 6 sided wrench and prybar to break loose then ratchet. After that pull whole assembly out and whalla.
1 Offline
I searched in tech talk and engine talk. Could not find the subject on steering column removal. So if anyone has more info please add and add to the proper site location. Thank you!
1 Offline
GMONIZ, Thank you for posting this I don't know why I couldn't find it. I probably got too specific on my search. This stovebolt sight is wonderful it has been very helpful to me so far.
You're welcome. Did you notice I just used what you had posted in your subject line? The key is to use the SEARCH In the upper tool bar only, not in the middle bar next to FAQ.
Leo Offline
Moderator
Moderator
I went by the truck manual. I took the steering box and the column out as one unit. You need to remove the 3 bolts holding the inner fender to the firewall, also the left fender to cowl brace and the driver's seat. The column comes out over the top of the grill, not out from underneath.
1 Offline
yes I noticed, and yes I used the search on left of screen not the top one. I will use the top one from now on thank you for all your help!
The steering gear box will come out the bottom as well,at least on my suburban it did.
Tim
1951 3100 Chevrolet
