7 members (Hotrod Lincoln, Dave1234, IHPWR, TUTS 59, Peggy M, Wayne67vert, 1 invisible),
72
Mod | | | Forums66 Topics128,206 Posts1,057,440 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 105 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 105 | I have a 52 chevrolet 3600. I was going to replace the master cylinder and wheel cylinders. The 3/4 ton 52 parts are almost double the cost a lot of places then the same truck of different years. Why is this? If Im not going to tow anything. Will the half ton parts bolt up or is this a terrible idea? I only need this to work for a short time a year or so. Until I get the truck into my garage to tear it apart to start the resto. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | That would be a bad idea and probably wouldn't work. The market for the larger truck parts is smaller and there is less competition.
| | | | | Joined: Aug 2010 Posts: 105 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 105 | after the restoration I plan on disc brakes in the front. I want to go with a new suspension in the front.
| | | | | Joined: Aug 2010 Posts: 105 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 105 | Thought it would not work. Thought I would ask
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | 52 was the last year for the huck brakes on the 3/4 ton models. The parts for those are rare & expensive. Try to rebuild the cyls. you have. Hone them out & if there is no pits in the surface that the cups contact they should work OK. You could get the brakes off a 53 up & change it over but that would take a lot of parts sqrounging. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2010 Posts: 105 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 105 | Thanks Wrenchbender... that makes sense. | | |
