0 members (), 46 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#78049 05/26/2007 7:18 AM
wondering if any of you guys have any pics. of how/where you mounted your coil that comes with langdons hei dist.
#78050 05/26/2007 4:08 PM
What kind of truck do you have?
#78051 05/28/2007 1:58 AM
Just for cosmetic purposes, I would use the older style round coil. An MSD Blaster 2 makes a good coil. The stock coil isn't quite as hot, but works. For use with an HEI you need to remove the ballast resistor. It's also a good idea to run a new wire for the coil. Go from the ignition side circuit to the coil with a 14 or 12 gauge wire. With the HEI, you don't need the wiring through the starter.
Fred
52 3600
69 C-10
#78052 05/28/2007 4:47 AM
I have it on my engine. You can see it in the photos.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#78053 05/28/2007 1:16 PM
Here's a picture withe mini HEI on my 261.
http://rides.webshots.com/photo/2868467590010188466onvLJi
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
