| | | Forums66 Topics128,012 Posts1,055,318 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78049 05/26/2007 7:18 AM | Joined: Feb 2006 Posts: 112 Member | | Member Joined: Feb 2006 Posts: 112 | wondering if any of you guys have any pics. of how/where you mounted your coil that comes with langdons hei dist. | | |
#78050 05/26/2007 4:08 PM | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | What kind of truck do you have? | | |
#78051 05/28/2007 1:58 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Just for cosmetic purposes, I would use the older style round coil. An MSD Blaster 2 makes a good coil. The stock coil isn't quite as hot, but works. For use with an HEI you need to remove the ballast resistor. It's also a good idea to run a new wire for the coil. Go from the ignition side circuit to the coil with a 14 or 12 gauge wire. With the HEI, you don't need the wiring through the starter.
Fred 52 3600 69 C-10
#78052 05/28/2007 4:47 AM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I have it on my engine. You can see it in the photos. | | |
#78053 05/28/2007 1:16 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | | | |
