| | | Forums66 Topics128,163 Posts1,057,044 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 230 'Bolter | | 'Bolter Joined: May 2005 Posts: 230 | Hi Guys...
I have a 1965 C30 Dump with a 292 and a 1 barrel carb. The throttle shaft is worn and allows air to get in causing the idle to go up especially at a stop light.
Is there a kit out there to repair this? I did a search and did not find one.
...Russ
1960 Chevy Apache (C10) 1965 Chevy C30 Dump Truck 1966 Chevy C30 Tow Truck | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Most carb shops can put bushings in your base plate for you. Check the yellow pages and call around. | | | | | Joined: Feb 2000 Posts: 5,233 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,233 | I bought a reamer and some bushings form McMaster Carr and did it myself. Once you buy the parts, you can do a lot of them for cheap. The bushings are standard size along with the shaft. To trick is getting the throttle blades off with out breaking the screws. Once thats done, its a easy repair with a standard drill press. Joe | | |
