2 members (Joe H, Naturalthud),
196
0
Mod | | | Forums66 Topics128,080 Posts1,056,062 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#77940 05/23/2007 5:06 PM | Joined: Jan 2007 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 172 | Ok...once upon at time I pulled the rear cover off the axle cleaned it all up, re-sealed, filled with fluid.
Well...I have found another leak that wasn't evident until fluids were added.
First - The right rear wheel has a thick, black, greasy crud all over the back/bottom of the brake plate (forget what that is called). Something is leaking...can't tell if it's brake fluid or axle oil. No real distinctive smell.
Second - Seems I wasn't so good with the first re-sealing of the rear cover plate...it is now 'damp' with gear oil. No leaks in the drive way, but if you run your finger around the bottom half...lots of good red Lucas Oil on your finger.
SO...since the front brakes were in HORRIBLE shape...and I have an unknown leak....
I am thinking pulling the rear and just working it over. New cylinders, find leak, put new gaskets on rear cover and front pumpkin (it has slow leak too). Maybe consider different gears? (At least count them so I can check if original 5.14 like book says.)
Maybe even paint it all up before remounting to preserve it.
So...this sounds crazy to me...and it sounds like weeks worth of work for me. I have impact wrench, 2 ton jack, jack stands...and probable need to build a roller of some kind.
Anyone have ideas that would be effective but less crazy? (Getting to the shoes/cylinders on my 1 ton seem to require pulling out parts of axle anyway.) 1965 Chevy C-30 1-Ton "Work like you don't need the money. Love like you've never been hurt. Dance like nobody's watching." | | |
#77941 05/23/2007 7:55 PM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | The less crazy thing to do is leave the housing where it is, still attached to the truck. You can do all the things you mentioned almost as easily in place as you can with it sitting 8' behind the truck if you were to remove it.
I see no advantage to removing the rear in your case.
Grigg | | |
#77942 05/23/2007 8:44 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Agree. You can pull the hubs off & service the brakes & axle seals. Getting the hubs/drums on correctly is crittical though. Are you shure the pinion seal is not leaking & running back to the rear cover. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#77943 05/23/2007 9:22 PM | Joined: Jan 2007 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 172 | Originally posted by Wrenchbender Ret.: Are you sure the pinion seal is not leaking & running back to the rear cover. Yeah, the bottom of the arms of the housing are bone dry. This gunk is just on that brake backing plate...starts about halfway down and gets heavy/thick at bottom. 1965 Chevy C-30 1-Ton "Work like you don't need the money. Love like you've never been hurt. Dance like nobody's watching." | | |
