5 members (Jon G, baldeagle, Nick in Manitou, TexasJim50, Woogeroo), 66 guests, and 2 robots.
Topics128,014
Posts1,055,332
Members48,419
#779297 09/09/2011 3:50 AM
My 1946 Chevy Stylemaster 235 Engine Installation has been a roller coaster. I finally got a ride in the car today, and I forgot how much fun it was. It was a great feeling.... until the rear main seal started leaking like crazy. Now what are my options? I would hate to have to pull this thing out again, especially after I got it running so well.
What a day.
DG
1946 Chevy Stylemaster Sedan - 216 6 Cylinder
1971 Chevelle SS
1995 Monte Carlo Z34
2005 Corvette Z51
Danspeed1 #779353 09/09/2011 12:17 PM
If it is just rear main seal you can change it by removing oil pan and rear main cap with out removing engine.
kb3csw #779373 09/09/2011 3:05 PM
Yep +1
Craig
cmayna #779398 09/09/2011 4:20 PM
But you have to do it on a gravel driveway with a mud puddle. grin
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
FriedGreenTmater #780003 09/12/2011 3:38 AM
I think it will make it to my friends house....
What do I do with the mud puddle?
DG
1971 Chevelle SS
2005 Corvette Z51
Danspeed1 #780007 09/12/2011 3:40 AM
Are there any "short cut" directions online on how to do this. I found that there are two types of seals. The original rope type and a new rubber composite type (which is the one I think I would go with). All the directions I found so far states the transmission needs to be separated from the engine and the crank needs to be lowered from the engine. This is something I've actually never done, but neither is swapping a stovebolt so I guess there is a first for everything. Thanks for the tips and advice!
DG
1971 Chevelle SS
2005 Corvette Z51
Danspeed1 #780009 09/12/2011 3:44 AM
Drop parts in it.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Mr. Lang #780081 09/12/2011 10:58 AM
If you want real success, you should adjust the main bearings at the same time. I would say that you should separate the transmission and lower the crank a bit. Having the minimum clearance on the main bearings, all of them, really helps. I used a piece of picture hanging wire to pull in the top half of the seal. The bottom half I rolled in with a socket. My seal doesn't leak at all.
1951 1 Ton Completed
