0 members (), 61 guests, and 4 robots.
Topics128,024
Posts1,055,395
Members48,422
#779175 09/08/2011 8:28 PM
I have a 54 chevy with 235. Awhile ago, i noticed that my radiator was leaking badly as soon as the truck warmed up. I took radiator to radiator shop and had it cleaned and there were no leaks at all. Put a new thermostat in as well. Whenever truck starts to warm up, the overflow tube starts draining all the fluid in the radiator. any ideas what could cause this? thanks!!
1954 Chevy 3100. Original 235 and Hydramatic
www.cardomain.com/ride/2344117
over filled radiator. the level should be down near the top of the fins. once it starts out the overflow it probably is just siphoning it off. does it quit once the level is down some?
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
what Vern says - note that you're usually adding water when it's cold, as temperature goes up, water expands
if you check the level when it's up to normal temp, it should still be at least an inch or 2 down from the fill neck
it will drain until the radiator is dry. that is why i noticed it, it will empty the whole radiator unless i turn the truck off. the engine temp goes way above normal also.
In that case, a new thermostat does not necessarily mean a good thermostat. remove it and test it in a pot on the kitchen stove. If the kids ask you are making thermostat soup for supper.
1953 Chevrolet 3600
might check to see if you have water in the oil,
or water coming out of the tail pipe, it has to be going some where...and if the rad goes dry I would think the temp for sure would go above normal, like hot
Redryder pix
My Hotrod
will check that tomorrow, hoping its something that simple! thanks again for the quick reply!
well i switched thermostats, and leveled the antifreze. seems to be working now. may have just been the thermostat. i appreciate all the responses!
so the thermostat was stuck and caused all the coolant
to boil out and make the rad dry... the temp gauge should have
warned of that by being really hot...
glad that is all to it though...
Redryder pix
My Hotrod
