2 members (Peggy M, panic),
89
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 96 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 96 | Mornin' I want to put a tonneau cover on the bed of my 55 series II, lwb / stepside model 3200, pickup. Dealer says I need a 97" long model. When I measure the inside dimension of the box (front to back) I have 88.5". Now they are suggesting that maybe someone put a different box on my truck. Who's right? As far as I can tell, my pickup is all original. It's only got 76,000 miles on it. Thanks! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | you may be mis-measuring sepp, see here, measure the floor .... but for a cover, isn't the 97" an outside measurement? will the cover be on top the bed or fit inside it? Bill | | | | | Joined: Jul 2010 Posts: 96 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 96 | THANKS BILL, THE DEALER SAYS THAT 97" SHOULD BE THE BED LENGTH INSIDE THE BOX. YOUR "SEE HERE" SAYS 90" IS CORRECT: MY 88.5" MEASUREMENT WAS AT THE TOP OF THE BED SIDE PANEL. IF I MEASURE AT THE FLOOR, I'LL PROBABLY COME IN AT 90". SAM | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | maybe check with Mar-K for bed board lengths for the long step bed, I don't currently have one, but I don't think 97" is right
Bill | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Take the dealer the truck, if they're sure what they're recommending will fit leave them to it, they ought to know their product. Just be sure it fits before you drive away.
I don't see how arguing over what length it is or should be matters so long as the finished product is what you expect. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Probably a metric conversion error. Do what Grigg sez. | | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | The board kits we sell for that model would have 89" long boards and strips, add an inch for the rear sill and the inside length would be 90". 97" length boards did not come along until 1957 model. As was mentioned above, just make sure the cover fits your bed before you buy.
