3 members (klhansen, Steelonsteel, 1 invisible),
93
Mod | | | Forums66 Topics128,208 Posts1,057,443 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I was at the scrap yard recently when I spotted a 'bolt with a powerglide in the corner. What really caught my attention was, no draft tube and what appeared to be a factory PCV. The valve cover was a center fill type, it had a hose fitting about 3/4 of the way back that probably went to the air cleaner. (which was gone) It also had a hose fitting about 1/3 of the way back that I'm guessing went to the pcv and another fitting screwed into the leg of the intake. It all looked factory done to me. I've never seen a bolt set up this way, if anyone else has, I'd sure like to know. Next time I'll try to get some pics. | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | The factory didn't install PCVs till 63-64 IIRC. They were required to be installed back to 1952, in CA anyway. There were several kits available for installation, this is probably what you found.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | | OLTrucks Unregistered | | OLTrucks Unregistered | Was this Bolt A GMC by chance? | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | No, Had Chevrolet on valve cover. Had casting number 3836848 on head, telling me it's a 56 model Chevrolet. I didn't get castings off block, since they're covered by motor mounts. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | As posted by Brad:
A PCV type of "ventilation" system was first used as standard equipment by Chevrolet in 1948 on the model 3742, a Forward Control Delivery Chassis, updraft carburetor: crankcase ventilation: "closed system, vacuum operated" (1949 description). This was not available on COEs (standard or optional) at that time.
Positive Crankcase Ventilation (by that name) was an option on COEs and some/most standard-cab large Chevrolet trucks by 1953.
In 1954, PCV was optional on all sizes of trucks with either the 235 engine or on trucks that could have the optional 261 engine. In 1954, the 261 engine was an option only on 1.5 and 2.0 ton trucks; and, the PCV option was a separate option (not necessarily installed with the 261 engine option).
