4 members (DadsFirstPickup, BC59, Lightholder's Dad, Otto Skorzeny), 127 guests, and 2 robots.
Topics128,135
Posts1,056,422
Members48,441
#77851 05/21/2007 10:03 PM
This may be a loaded question, but remember I'm talkin trucks here.
How do you guys seal your rear end. Both the rear cover and the front side. I'm in the process of transplanting a 55 pumpkin into my 46 rear.
George
#77852 05/21/2007 11:04 PM
Riding in the Passing Lane
Gaskets are available for both. The front one is very thin. If you clean the surfaces good & there is no high spots you can put the gasket over the studs & install the pumpkin. The rear one I glue the cover gasket with hardening gasket cement to the cover. You can use a thin layer of RTV on the other side or you can just put it on with RTV. This is a good time to replace the axle seals if they don,t look good.
George also
1972 Chevy c10 Cheyenne Super
#77853 05/22/2007 5:06 AM
I have found a thin coat of Permatex #2 on both sides of the gasket to be very effective. Squeeze a small bead around the gasket, then smear and pat it around with your finger, so it is evenly coated. Same on both sides, use a piece of wax paper when you flip the gasket over, or just regular paper works too. Clean and dry the mating surfaces and install. Also use #2 on the threads of the bolts to seal them.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
#77854 05/23/2007 3:44 PM
If you seal up your rear end, won't your eyes turn brown pretty quickly?
#77855 05/23/2007 3:52 PM
Gives you a crappy outlook..
---All pictures---
#77856 05/23/2007 4:06 PM
I knew this post was going to down hill fast. Thanks for the laugh this morning. grin grin
So what kind of sealent do you use?
George
#77857 05/24/2007 1:21 PM
I swear by Permatex Black Silicone, item# 81158
16B , it seals best in my opinion an is tough as heck when cured , an on older trucks without O2 sensors an such there is NP with the silicone.
I prefer it over there Blue glue or other mixes.
1952 Chevy Shortbed
Photos in Photobucket
#77858 05/24/2007 5:08 PM
I had problems for years trying to get gaskets not to leak. Someone told me about General Motors Gasket Sealer. It is the best stuff in the world. It almost never leaks when I use it and it is very easy to clean up when removing a gasket. It is General Motors Part Number Gr. 8.800 - 1#1050026. You can buy it in a can with a built in brush at your local Chevrolet dealership parts counter.
Joe smile
