2 members (Hotrod Lincoln, greenie-reddy), 96 guests, and 2 robots.
Topics128,049
Posts1,055,741
#778441 09/06/2011 2:54 AM
I have a large hole in the linkage arm for a much smaller rod in my 59 apache 3100. Is this correct or should there be a bushing in that hole? Please see photo.
Thanks Larry
http://s1189.photobucket.com/albums/z434/camsore/?action=view&current=IMAG0386.jpg
3B Offline
Hy Camsore, that hole is definately worn a bit, but there is no bushing in that hole normally. You could weld up the obviously worn part and redrill the hole, don't make the hole too small for the shaft or the linkage might bind. I put a flat washer on both sides of the arm, and then a cotter pin to retain it, hope that helps.
