0 members (),
51
7
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#77828 05/21/2007 4:09 PM | Joined: Feb 2007 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 56 | Hello from Wisconsin! I have a 59 Apache with stock 6 cyl... do the engine mounted brackets transfer from the 6 to the v-8? I also question the length of the threaded rod... different from 6 to 8? Thanks, Grant. | | |
#77829 05/21/2007 4:19 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | hello yerself Grant! the 6cyl engine brackets are slightly different than the V8 , tho they can be modified to work - the 6cyl pins have a different configuration, tho' again, can be modified to be like the V8 pins - OTOH, the complete mount kit is available from the vendors, with all the correct rubber and washers - also if you have a factory 6cyl setup you need the frame brackets that come with the kit, the 6/8 mounts are in a different place Bill | | |
#77830 05/24/2007 6:11 PM | Joined: Feb 2007 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 56 | Hi Red 58! Wow, thanks for the education! Did you have those pics, or take them just for me? It is really appreciated! I looked at a 55 car over the weeekend, and it got me thinking... (sounds dangerous for someone!) but your pics showed me the brackets attaching things to the crossmember. Leads to another question... am I better off getting the stock style for $100, or the crossmember kit with mounts for a little less $$. I am not planning on thrashing on things, but you never know when the need for a little "rubber" will be there. (I occasionally like to turn the tires) What do you think? Grant. | | |
#77831 05/24/2007 7:32 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I think the stock setup is better - nothing across below the pan, no frame welding - I've got a pretty strong 283 in the 58 and it'll spin the tires anyday with no danger ... the only need for the side mounts is if you have an automatic that doesn't have the bellhousing mounts and the pics were on hand from previous discussions, I try to take pics of everything I can so it's easier to explain .... or prove Bill | | |
