6 members (Gdads51, J Lucas, Shade Baby, Lightholder's Dad, Otto Skorzeny, rfs56trk), 71 guests, and 1 robot.
Topics128,038
Posts1,055,585
1952 3100 can't figure out why this is happening. truck sat for 25 years. everything else works. i took speedo apart but cannot find anything wrong. any and all help would be appreciated.
Sorry Ed,I'm not well versed on the mysterys of the inner workings of speedometers.
It might be something as simple as stuck/gummed up.
The light grease they were lubed with may have turned to gloop over the decades.
Especially as the truck was dormant for 25 years.
I know when I tore into mine the grease was like wax.
One of our Stovebolt stalwarts Denny Graham seems to know his way round these things,it might be worth sending him a PM.
If not,i'm sure he'll know someone who does.
More pix on Flickr.
jb,
it does work with an electric drill motor tho. if the cable is broke would the speedo still function?? i will pm denny.
thanks,
ed
Ed - the speedo and odo are 2 different animals, the number wheels have tiny plastic tabs on the sides of the wheels that catch the wheel next to them and pull it along when turning past 0 - after many years if the shaft gets gummy, the force needed to turn the adjacent wheel can be enough to break off one of the tabs, usually toward the right so all the numbers stop turning
to fix the odometer you'll need to get a set of replacement wheels from a donor unit, and follow the help in the tech tips
Gonna give you your answer here Ed, someone else may have the same problem one day:
http://www.pbase.com/dennygraham/image/137816956/large
http://www.pbase.com/dennygraham/image/137816993/large
Unfortunately one of the gears is probably sheared of in the head. The needle cup is
free floating and is driven by a magnet which is driven by a solid connection to the cable.
The magnet is also directly connected thru gears to the odometer.
Or as Bill mentioned it could be the drive tabs are broken.
If the needle is giving you a reading then the cable is good and is driving the main shaft
of the head.
Look familiar John????
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
thanks denny,
i am pretty sure it moved when i had my electric drill on it, but i will pull it again and try it. i hate to touch it because it is an original speedo w/17000 miles. truck title is clean w/14999 actual mi on last purchase in 1986!!
if both the driving and driven gears are turning and the wheels aren't, you'll either 'touch it' and replace the wheels with broken tabs or do without an odometer - it may be why it has such low mileage showing wink
bill,
you are right. it probably doesn't matter what the odometer says these days on a 60 year old truck. i guess i'm just being anal about it because everything else works great. thanks for the replies though!!
-e-
Denny Graham
Yes Denny,that's why I name dropped you in my first post!
More pix on Flickr.
I kinda depend on that odometer as a double check on the fuel gauge. Guess it's a throw back to my flying days when I didn't trust the fuel gauge but rather used the hours flown or what I still do on the motor cycle, hit the gas pump when I'm at 150 miles or else I'll be pushing it to the pump.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
That ain't a problem! That's a blessing!!!!! Lol
Do something! Even if it's wrong!
Moderated by  ndkid275, Phak1
