| | | Forums66 Topics128,035 Posts1,055,570 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 13 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 13 | 1952 3100 can't figure out why this is happening. truck sat for 25 years. everything else works. i took speedo apart but cannot find anything wrong. any and all help would be appreciated.
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Sorry Ed,I'm not well versed on the mysterys of the inner workings of speedometers. It might be something as simple as stuck/gummed up. The light grease they were lubed with may have turned to gloop over the decades. Especially as the truck was dormant for 25 years. I know when I tore into mine the grease was like wax.
One of our Stovebolt stalwarts Denny Graham seems to know his way round these things,it might be worth sending him a PM. If not,i'm sure he'll know someone who does.
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Feb 2007 Posts: 13 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 13 | jb, it does work with an electric drill motor tho. if the cable is broke would the speedo still function?? i will pm denny. thanks, ed | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Ed - the speedo and odo are 2 different animals, the number wheels have tiny plastic tabs on the sides of the wheels that catch the wheel next to them and pull it along when turning past 0 - after many years if the shaft gets gummy, the force needed to turn the adjacent wheel can be enough to break off one of the tabs, usually toward the right so all the numbers stop turning to fix the odometer you'll need to get a set of replacement wheels from a donor unit, and follow the help in the tech tipsBill | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Gonna give you your answer here Ed, someone else may have the same problem one day: http://www.pbase.com/dennygraham/image/137816956/large http://www.pbase.com/dennygraham/image/137816993/large Unfortunately one of the gears is probably sheared of in the head. The needle cup is free floating and is driven by a magnet which is driven by a solid connection to the cable. The magnet is also directly connected thru gears to the odometer. Or as Bill mentioned it could be the drive tabs are broken. If the needle is giving you a reading then the cable is good and is driving the main shaft of the head. Look familiar John???? Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Feb 2007 Posts: 13 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 13 | thanks denny, i am pretty sure it moved when i had my electric drill on it, but i will pull it again and try it. i hate to touch it because it is an original speedo w/17000 miles. truck title is clean w/14999 actual mi on last purchase in 1986!!
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | if both the driving and driven gears are turning and the wheels aren't, you'll either 'touch it' and replace the wheels with broken tabs or do without an odometer - it may be why it has such low mileage showing  Bill | | | | | Joined: Feb 2007 Posts: 13 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 13 | bill, you are right. it probably doesn't matter what the odometer says these days on a 60 year old truck. i guess i'm just being anal about it because everything else works great. thanks for the replies though!! -e- | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Yes Denny,that's why I name dropped you in my first post! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I kinda depend on that odometer as a double check on the fuel gauge. Guess it's a throw back to my flying days when I didn't trust the fuel gauge but rather used the hours flown or what I still do on the motor cycle, hit the gas pump when I'm at 150 miles or else I'll be pushing it to the pump.
| | | | | Joined: May 2010 Posts: 85 New Guy | | New Guy Joined: May 2010 Posts: 85 | That ain't a problem! That's a blessing!!!!! Lol
Do something! Even if it's wrong!
