| | | Forums66 Topics128,013 Posts1,055,312 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I was just wanting to see if anyone out there has boxed the frame on their AD truck. On trucks that are 50-60 years old, I can't help but think that boxing the frame is a good thing. After years of rust and abuse, I'm sure there are plenty of stress cracks and stress points that you may or may not even see. I just want to get someone else's take. | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | If stress points are present due to cracks, boxing isn't likely to make them go away. The frame was designed to flex to some extent, and making it totally rigid will increase the possibility of a break, IMHO. I can see the advantage of doing some limited reinforcement at stressed areas like add-on motor mounts or crossmembers where they weren't originally engineered to be, but I doubt that doing a full boxing job is necessary. If you're installing something with a massive amount of torque like a big block V-8 or a high torque Diesel engine, why not just fabricate an entire frame out of rectangular tubing, using the original frame as a template? Jerry
| | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | When my son and I was restoring the '45, we had it completely striped to the bare frame. Although there was no issues with the frame, I was amazed how light and flexible it was. We actually picked it up and flipped it over by hand to work on the underside and it seemed almost flimsy. | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | It only resists bending strongly in the vertical plane, not racking or twisting. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | another thing to always consider when discussing any frame alteration is the condition of the frame. As Whitedog states "after years of rust and abuse" your likely to do more harm than good. ALL the rust needs to be removed for any proper welds amd it is doubtful you'd ever get it that clean. If the frame is that weak then bolting a 12 gas angle to it would be a better fix where it is needed. 12 ga? So you think that's too light? It is probably heavier than the original or close to it.
Believe me boxing will gain you nothing except weight and too much stiffness in all the wrong places. If it's lasted 50-60 years don't get excited and think you must re-engineer it. It will be fine,
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | My problem is that I watch too many car shows. Stacey David, The guys on TRUCKS, and Extreme 4x4, seem to box in everyhting. I'm not planning on a big block build or rock crawling. I may do some suspension upgrades and that's abou it. | | | | | Joined: Jun 2011 Posts: 150 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 150 | All I can say is my first bolt was a 49 with an Olds Rocket in it and no frame work. When you jumped on it, it felt like a Flexi-Flyer. My current build is another 49 with a small block and Camaro clip. I have boxed it to half way back under the cab. We'll see how it handles. | | | | | Joined: Dec 2010 Posts: 280 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 280 | im going to box mine front to back. but its getting a M-II front end a big block and a mosier 12 bolt rear connected by a 4 link.
*UNDER CONSTRUCTION* 1953 Chevrolet 3100 1/2 ton-previously abandoned resto. My Project BoltI hate when people leave their brains at home. Seriously when did critical thinking and customer service go out the window? How about common sense and striving to go the extra mile? Idiots, surrounded by idiots it tell you.
