2 members (carbking, RLB),
157
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 150 | I was hoping someone might be able to help me. I just took my 54 out on it's first trip around the block sinse getting it. It has a 4speed tranny. Reverse works fine, It moves through all the gears just fine. After taking off in 2nd gear, it does just fine, but when i go to third it falls on its face and wants to die, acting as if the engine speed is not high enough, but that is not the problem. Is it some kind of transmission problem or does it have to do with the carb. or some other engine problem?
Thanks, Darren. | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Try advancing the timing a little, or do a fuel pump output volume test. It's possible the torque of the engine just isn't up to the load you're putting on it, but if that's the case, there's something seriously wrong that's limiting the engine's power. It should accelerate in third gear smoothly from about 15-20 MPH or more. Jerry
| | | | | Joined: Nov 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 150 | I think the fuel pump may need replacing, it's putting out fuel but just at a trickle. | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | How does it go in 4th? With my SM420, I used 3rd a lot for city driving. I wore out one third gear and now a second is starting to sing. I suspect the shaft and bearings are worn. All the other gears worked fine and were generally quiet.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Nov 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 150 | It slides right into 4th fine too, then falls on face just like 3rd. But all is quiet. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I think the fuel pump may need replacing, it's putting out fuel but just at a trickle. sounds like you have the solution, I suspect when it bogs down if you shut it off and check the carb you'd find the bowl near empty Bill | | | | | Joined: Nov 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 150 | Thanks guys, ill let you know if that fixes it. | | | | | Joined: Nov 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 150 | The fuel pump seams to have been the culprit. Thanks for all the help guys. | | |
