as Rich says, the hinges can be adjusted in the door and in the post [
pic in manual] ... the leading edge of the door
should be very slightly inboard to avoid interference with the fender when opening, the trailing edge should be fairly flush but sometimes the seal will hold it out a bit, and there should be some rubber bumpers on the back post that keep the door tight against the striker - there's more info in the manual
