3 members (Hotrod Lincoln, Chip O, Steelonsteel), 125 guests, and 3 robots.
Topics128,196
Posts1,057,391
Members48,471
I just took the gas tank out of my truck and I was told to take it to a radiator guy in town to get it overhauled. The guy told me that he is going to clean/boil the tank and coat it on the inside. He said that it was going to cost $125. Being that this is my first restoration, does this sound right? Do I need to ask any additional questions?
That's what it cost me 4 years ago before new gas tanks were available. Seems like a fair price to me. Jim Carter does sell reproduction tanks, you may consider buying new. I can not vouch for the quality of the JC tanks, but the price seems pretty reasonable as well.
I put one of Carter's tanks in my '41 and everything fit correctly and it looked almost exactly like the original tank which was needing some attention. The only thing different was the tray the tank sits in on my early '41 had only one hole, as did the tank, and the new tank had two. So I took my hole saw and made the cooresponding hole on the other side. Gives me a drain plug as well as the regular shut off. I am pleased with the tank. The filler neck lined up with the hole well.
Opportunity is missed by most people because it is dressed in overalls
and looks like work. - Thomas Edison
1941 AL 3/4 ton 125-1/4 WB, bought by my Great Uncle Matt in 1942. Still in the family.
I just had the tank cleaned and lined on my '40 WB 1-1/2 Ton. It cost $200. The shop did a great job. I wanted to keep the stock tank, if possible. My grandfather bought this truck new in 1940
1939 GMC AC-102 Long Bed 1/2-Ton
In the Legacy Stovebolt Gallery
More details in his DITY Bay
1940 Chevy WB Series 1.5-Ton
Ex Hall Monitor
Ex Hall Monitor
See if he offers a warranty. Those who don't follow the manufacturer's directions often find the coating peeling which creates blockage issues. I've had good luck with coatings but I'm pretty good at following instructions. Several here have not had as good luck.
Thanks a lot for the comments. I will only have 10,000 more questions before my truck is finished...
