0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#77623 05/15/2007 10:36 PM | Joined: Jul 2006 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 92 | On the conversion kit to put a 283 in a 50 do you have to cut the crossmember part as well as the end pieces? I think my buddy said we would have to cut about 1 1/2 " off the end pieces that go on the frame and some off the tube crossmember part. Don't want to cut and mess things up. Also it looks like the crossmember is going to have to go just about over the axel. Sound right? Thanks....Virg | | |
#77624 05/15/2007 11:04 PM | Joined: Jun 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 191 | I honestly can't see why you'd have to cut the end pieces. You should be able to just trim a little off the crossmember part to give you enough play to get it between the rails. But then again I may be mistaken. | | |
#77625 05/19/2007 1:04 PM | Joined: Jul 2006 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 92 | Anyone else have an opinion? Thanks...Virg | | |
#77626 05/19/2007 2:25 PM | Joined: Jun 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 191 | Here read this: CPP Article I can't see how it would be different than their transmission crossmember which I already put in. I have a tubular engine crossmember being delivered here next week to replace my front mount setup on my SBC so I'll be able to let you know for sure probably mid-week on what I see firsthand putting it in. | | |
#77627 05/19/2007 8:58 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I just cut enough off the ends of the crossmembers to make it fit. After fitting everything I drilled holes through the ends & crossmember & bolted them together. If you weld them you will not be able to remove it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#77628 05/19/2007 10:07 PM | Joined: Jul 2006 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 92 | robin58....that's what I was looking for...thanks...Virg | | |
#77629 05/22/2007 12:36 PM | Joined: Jul 2006 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 92 | does anyone have info on moving the steering box away from the frame on the 283 eng. swap? Thanks Virg | | |
#77630 05/22/2007 10:49 PM | Joined: Jul 2006 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 92 | Also the S10 rearend I have is smaller hub to hub and spring perch to spring perch narower. Do I need to mover the spring perches? Virg | | |
#77631 05/23/2007 2:30 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I have a photo of an old rusted GMC that had a 283 installed. http://rides.webshots.com/photo/2398937530041873203QNOSEV I took the photo under the hood on the weekend because it appears that the steering box may be original. Also, on one side the exhaust manifold exits to the front and on the other side it exits to the rear. I would guess that the arrangement is different from the original 283 exhaust? | | |
#77632 05/31/2007 7:02 PM | Joined: Jun 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 191 | Well virg912iowa I can tell you your friend was pretty close. I put my crossmember in today. I had to take 3.5" of each side of the crossmember and a tad over 2" off each of the end pieces to stop it from butting up against the curve.. | | |
