3 members (Guitplayer, Charles in CA, 1 invisible), 65 guests, and 2 robots.
Topics128,030
Posts1,055,418
Members48,422
#77623 05/15/2007 10:36 PM
V
V Offline
On the conversion kit to put a 283 in a 50 do you have to cut the crossmember part as well as the end pieces? I think my buddy said we would have to cut about 1 1/2 " off the end pieces that go on the frame and some off the tube crossmember part. Don't want to cut and mess things up. Also it looks like the crossmember is going to have to go just about over the axel. Sound right? Thanks....Virg
#77624 05/15/2007 11:04 PM
I honestly can't see why you'd have to cut the end pieces. You should be able to just trim a little off the crossmember part to give you enough play to get it between the rails. But then again I may be mistaken.
#77625 05/19/2007 1:04 PM
V
V Offline
Anyone else have an opinion? Thanks...Virg
#77626 05/19/2007 2:25 PM
Here read this:
CPP Article
I can't see how it would be different than their transmission crossmember which I already put in.
I have a tubular engine crossmember being delivered here next week to replace my front mount setup on my SBC so I'll be able to let you know for sure probably mid-week on what I see firsthand putting it in.
#77627 05/19/2007 8:58 PM
Riding in the Passing Lane
I just cut enough off the ends of the crossmembers to make it fit. After fitting everything I drilled holes through the ends & crossmember & bolted them together. If you weld them you will not be able to remove it.
1972 Chevy c10 Cheyenne Super
#77628 05/19/2007 10:07 PM
V
V Offline
robin58....that's what I was looking for...thanks...Virg
#77629 05/22/2007 12:36 PM
V
V Offline
does anyone have info on moving the steering box away from the frame on the 283 eng. swap? Thanks Virg
#77630 05/22/2007 10:49 PM
V
V Offline
Also the S10 rearend I have is smaller hub to hub and spring perch to spring perch narower. Do I need to mover the spring perches? Virg
#77631 05/23/2007 2:30 PM
I have a photo of an old rusted GMC that had a 283 installed.
http://rides.webshots.com/photo/2398937530041873203QNOSEV
I took the photo under the hood on the weekend because it appears that the steering box may be original. Also, on one side the exhaust manifold exits to the front and on the other side it exits to the rear. I would guess that the arrangement is different from the original 283 exhaust?
1951 1 Ton Completed
#77632 05/31/2007 7:02 PM
Well virg912iowa I can tell you your friend was pretty close. I put my crossmember in today. I had to take 3.5" of each side of the crossmember and a tad over 2" off each of the end pieces to stop it from butting up against the curve..
