5 members (Southerntruck, Phak1, NJC, Guitplayer, moparguy), 86 guests, and 1 robot.
Topics128,157
Posts1,056,877
Members48,458
#775609 08/27/2011 9:19 PM
Hi folks - photo of my oil filter canister and filler cap is linked below. Wanted to know if there is an element that goes inside this canister? Currently it just has a small amount of oil in it and no filter/element. On the top it has "AC" stamped on the bracket between the canister and the filler. Thanks for your help!
Oil Filter Photos 1951 GMC 1 Ton (238 straight 6)
It looks to me like you have some kind of air filter on the filler tube. I take it there are no lines connected to it?
1951 1 Ton Completed
There are no lines, it's attached to the oil filler neck. You're probably right, it's probably some sort of breather? On the carb side of the truck/manifold, there is no oil canister - that's why I thought perhaps that was it, but you are probably correct. thanks!
That's a breather on the oil filler tube. My friend has the same assembly on his 1949 GMC 228 engine. Chevy trucks did not have this assembly.
Moderated by  Dusty53
