4 members (Steelonsteel, bajabob, Hotrod Lincoln, 1 invisible), 172 guests, and 3 robots.
Topics128,261
Posts1,058,327
Members48,485
#775783 08/28/2011 4:50 PM
Hi fellas,
Although I have a 66 C20 pickup, I think this question applies to all old trucks. Does anyone know a good place to buy a new speedometer cable that can be adjusted to my new ring and pinion?
I took out the old Eaton rear end and put in a Dana 60 so I could put in a 3.54 ring and pinion. Now my speedo is way off, plus my old speedo cable is shot anyway. Who sells that stuff?
Thanks much!
1966 Chevy C-20 Fleetside Longbed
Photobucket pictures
"Better get busy livin' or get busy dying" ~ ...Morgan Freeman
The calibration of the speedometer is usually done in the speedometer not the cable. There is a torsion spring that can be calibrated to match your new gears and tire size. Another way might be to use a GPS system to make a mental calibration so you know how fast you are going compared to what speedometer reads. I use a GPS system exclusively as a speedometer and in the unlikely event that I should get "lost" I don't have to stop for directions.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
speedo cables, which are available at any FLAPS, are not "adjustable" ... when you change rear ratios you need to get a new speedo drive gear in the trans appropriate for the ratio - or do as Vern suggests and "mentally calibrate" the reading using GPS or another vehicle with a known correct reading speedo
thanks!
do you know then where I could search for the new speedo gear drive?
In addition to a new speedo cable, I think you need to be looking for either the correct driven gear(at transmission end of cable inside transmission), or a speedometer ratio adapter. Type speedometer ratio adapter into Google and see what pops up... thumbs_up
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
