| | | Forums66 Topics128,163 Posts1,056,918 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2000 Posts: 199 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 199 | I'm looking for the dimension from the radiator core support mounting holes to the first cab mount. I've got the 47-54 Truck Factory Assembly Manual and it only has this dimension up to the 3800/4100 trucks (the same as the 3100/3600 at 44.859").
I've heard many times it is '4" longer' on the bigger trucks but need the actual dimension to be sure.
If I need to, I'll lay under mine to measure but I was hoping for something a bit more precise. | | |
