1 members (1 invisible),
65
0
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 15 New Guy | | New Guy Joined: Mar 2011 Posts: 15 | i purchased a cylinder head thev other day, for my 235 block. but after close inspection, i noticed there were no holes for the valve cover to bolt on to.so this vmust be a 216 head? or am i missing something? any help would be great. thanks.
really like the stovebolt site. not the sharpest file in the drawer when it comes to computors. better at rebuilding parts. hope im in thanks guys rodC66
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | How many head bolts?
15 head bolts on all 216s and on low-pressure 235s 18 head bolts on high-pressure 235s and on all 261s
All low-pressure heads (216 and 235s) had two-bolt valve covers - bolts through the top of the valve cover.
1953 high-pressure 235 engines also had two-bolt valve covers. All other high-pressure 235s and all 261s had 4-machine screws valve covers (attachment at the edges of the valve cover).
| | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | What is the casting # and the date code.
Usually located on top, under the valve cover, across from each other.
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Tim, I don't have the bolt count in front of me but, there is also the 1950-52 Power Glide, splash 235, which is different than the 1941-49 235 head.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks, Dave. I had forgotten about that because I was only referring to valve covers.
| | | | | Joined: Mar 2011 Posts: 15 New Guy | | New Guy Joined: Mar 2011 Posts: 15 | well i checked the head bolts, there are 18 to the count. so it is a high pressure head. that is what i was wanting. my block is a full pressure 1954.i just didn;t know they still had the two bolt valve cover.thanks for the comeback. r/c66
| | | | | Joined: Mar 2011 Posts: 15 New Guy | | New Guy Joined: Mar 2011 Posts: 15 | hey tom, i have the casting numbers if you can identify them, that would be great. 3701887 gm 6 con13 1223. those were on top of the head, inside the valve cover. thanks. just trying to be sure. dad always said to measure twice and cut once.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 3701887 is a 1953 235 cylinder head The 1223 is probably a date casting code that might be I223, which would decode to: I = September 22 - 22nd 3 = 1953 Wait for Tom to confirm or correct. What is the block casting code and the block date casting code? http://1954advance-design.com/Web%20images/casting-code-photos/low-press-codes-ser-nums.htmlSo, it looks like you have a 1953 235 head that works with a later high-pressure block. The 1953 was a transition year for the 235 heads and blocks. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | 3718887 is a 235, 108hp 2stud rocker cover, 1953-62 listed in Mark Allen's Facrory Casting Number & Code Guide. This number is not listed in the 1929-57 parts book nor the 1929-54 parts book so it must have been a later release. And, it is not listed in the 1947-72 parts book. So my guess would be that it was a '58-'62 head that was later replaced by the 3836954 head.
3835913 is a 235, 108hp 4bolt rocker cover, 1954-57. If it is the stock truck motor of this vintage it would have this head on it.
3836241 Would have been the 1954-55 Corvette head.
3836848 Would be a 235, 108hp 4bolt rocker cover, 1956-62.
To further confuse things, in the 1946-72 parts book they list pn. 3836954 as a replacement for ALL 1953-62, 235.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | "3836954 as a replacement for ALL 1953-67, 235."
Denny, don't you mean 57? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | No Dave, if your looking in the 1929-57 parts book, that may indicat that. But in the 1946-72 1/2 to 1-ton Trucks parts book that I have it lists it as a replacement head for 1953 thru '62. The effective date of this parts book is May, 1977
And I made a correction to the typo i.e. changed the '67 to '62 which of course was the last year for that series.
| | | | | Joined: Mar 2011 Posts: 15 New Guy | | New Guy Joined: Mar 2011 Posts: 15 | thanks for the info . i am convinced that it is a 53 high pressure head now. as i said, i have 54 235 full vpressure block under it.and vthe head has vthe 18 count head bolts. so i believe i have a good set up to drop in my 1950 3600 series.i have had it all rebuilt at the local machine shop,that shrunk my wallet. my fat finger keeps hittin the v button, sorry. well thanks again to everyone who helped out.r/c 66.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | rodC66,
Yes, that should be a good engine in your 1950 3600. Please post a few photos when you have the engine installed.
