1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
Ok might be a silly question for yiunguys but how does the rear of the front lief spring mount? Right now both sides are haning just in front of the rear mount. Does the spring just sit on the pin? Any help would be greatly appreciated
Jody
[email protected]
Photos of the proper mount would be even better THaNKs
Last three picture here, click to enlarge:
http://www.pbase.com/dennygraham/3604_suspension&page=all
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
tHANKS. This is exceptionally helpful. Looks like I need two new springs I wonder if just the one piece the spring can be replaced
Thanks again
Jody
Oops, I just reread your post, you were interested in the Rear of the Front spring.
Sorry Jody, I posted the Front of the Rear spring. I'll shoot a couple of pics when I get
out to the garage after we break the fast.
Aw heck, I gotta wait for my coffee to brew up, I'll just run out and snap a picture for ya:
http://www.pbase.com/dennygraham/image/137563556/large
DG
Denny G
Sandwich, IL
Thanks Denny - this is very helpful. Looks like I need to rebuild both springs. They arensnapped off on both sides
Thanks again
Jody
Eaton Detroit Springs will sell the top leaf by itself.
Classic Parts sells a complete set for a good price. I do not know if their clips/clamps (rebound clips) look like the originals (if that matters to you).
Thanks Tim. I looked at the details and it says "works for 51 to 53 3/4 ton. I have a 3/4 ton- Will it still work?
Sorry I have a 49 3/4 ton
Jody,
Sorry about the bad link. I corrected it.
The 1949 1/2 ton and 3/4 ton front springs are not exactly the same, but they can be physically interchanged (same mounting dimensions). Rear springs are different.
Maybe someone (like Denny) will comment on the danger, if any, of using a 1/2 ton front spring on a 3/4 ton truck? If I was not going to heavily load the 3/4 ton truck, I'd go with the 1/2 ton spring.
Ok sounds good. I actually plan to keep the straight six in there so I should be ok. As long as the length etc are the same
Thanks again
Thanks Tim
