7 members (Gdads51, joe apple, 78buckshot, Hanks custodian, Otto Skorzeny, 1955 1 Series, Rexville48),
122
Mod | | | Forums66 Topics128,070 Posts1,055,896 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 34 'Bolter | | 'Bolter Joined: Jun 2011 Posts: 34 | Ok might be a silly question for yiunguys but how does the rear of the front lief spring mount? Right now both sides are haning just in front of the rear mount. Does the spring just sit on the pin? Any help would be greatly appreciated Thanks Jody [email protected] | | | | | Joined: Jun 2011 Posts: 34 'Bolter | | 'Bolter Joined: Jun 2011 Posts: 34 | Photos of the proper mount would be even better THaNKs | | | | | Joined: Jun 2011 Posts: 34 'Bolter | | 'Bolter Joined: Jun 2011 Posts: 34 | tHANKS. This is exceptionally helpful. Looks like I need two new springs I wonder if just the one piece the spring can be replaced
Thanks again Jody | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Oops, I just reread your post, you were interested in the Rear of the Front spring. Sorry Jody, I posted the Front of the Rear spring. I'll shoot a couple of pics when I get out to the garage after we break the fast. Aw heck, I gotta wait for my coffee to brew up, I'll just run out and snap a picture for ya: http://www.pbase.com/dennygraham/image/137563556/large DG
Denny G Sandwich, IL
| | | | | Joined: Jun 2011 Posts: 34 'Bolter | | 'Bolter Joined: Jun 2011 Posts: 34 | Thanks Denny - this is very helpful. Looks like I need to rebuild both springs. They arensnapped off on both sides
Thanks again Jody | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Eaton Detroit Springs will sell the top leaf by itself. Classic Parts sells a complete set for a good price. I do not know if their clips/clamps (rebound clips) look like the originals (if that matters to you). | | | | | Joined: Jun 2011 Posts: 34 'Bolter | | 'Bolter Joined: Jun 2011 Posts: 34 | Thanks Tim. I looked at the details and it says "works for 51 to 53 3/4 ton. I have a 3/4 ton- Will it still work? | | | | | Joined: Jun 2011 Posts: 34 'Bolter | | 'Bolter Joined: Jun 2011 Posts: 34 | Sorry I have a 49 3/4 ton | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Jody, Sorry about the bad link. I corrected it. The 1949 1/2 ton and 3/4 ton front springs are not exactly the same, but they can be physically interchanged (same mounting dimensions). Rear springs are different. Maybe someone (like Denny) will comment on the danger, if any, of using a 1/2 ton front spring on a 3/4 ton truck? If I was not going to heavily load the 3/4 ton truck, I'd go with the 1/2 ton spring. | | | | | Joined: Jun 2011 Posts: 34 'Bolter | | 'Bolter Joined: Jun 2011 Posts: 34 | Ok sounds good. I actually plan to keep the straight six in there so I should be ok. As long as the length etc are the same
Thanks again | | | | | Joined: Jun 2011 Posts: 34 'Bolter | | 'Bolter Joined: Jun 2011 Posts: 34 | | | |
