3 members (TUTS 59, Hawkman, MrSnerdly), 50 guests, and 0 robots.
Topics128,043
Posts1,055,615
#774868 08/25/2011 6:36 AM
Maybe I didn't search enough, 1hr & no matches, but here is what I've got and all I could figure out. can you provide more info on these numbers?
Block cast #
3837004 GM25
Block Ser. #
Fb05H
(Fint June ?? Truck)
Head cast #
3835913
GM10
('54 235)
These might be mismatch parts, they're out of a '55 3/4ton truck with 4sp trans.
'53 BelAir 261 3spd/OD 4dr
'54 3100 235 3spd
'79 C30 with a '51 235-'57Bellhousing-'67SM420-14bolt dually
'89 V3500 350/465/205 SRW CC
One Chevy just isn't enough.
3837004 1955 to 1957
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
F605H (Fb05H) might decode as:
F = Flint, MI plant
6 = May (oops, 6=June)
05 = 5th day
H = 3100 (and 3200, 3600, 3800) regular production engine/truck
Thanks.
I knew I was close to having it decoded but was stumped by the 605 in the F605H stamp.
Is this a full pressure with cam, crank and rod bearing inserts, not babbitt?
'54 3100 235 3spd
Originally Posted by DADS53
Thanks.
Yes
F = Flint, MI plant
6 = May
05 = 5th day
That matches with what my code books says. To be a little more specific, it's a '57.
Bill Burmeister
Thanks, Bill, I left that pertinent information out. 1957 it is (indicated by the "H" in the engine serial number).
You may be able to determine mismatched parts based on casting date codes.
Your stamped engine serial number, 605
is the date the engine was assembled.
I'm confused because I thought 6 = June.
Your block casting date code should be located near the 3837004 block casting number. Example - E127.
Your head casting date code is directly across from your head casting number 3835913. Example - D196.
Post the date codes and maybe we can help.
-Tom
1950 Chevy 3100 w/ 1956 235
Thanks, Tom,
I counted my fingers incorrectly (I have an imdigiment of the right hand).
I've added a correction and a note, above.
Im having the same problem... I just got a 1962 C-10 with a late year 350. I have been trying to decode it via only and I have only got so far. Casting # 3970010 and Block Stamp ID V0131TKK.I think I figured out the stamp as being
V=Flint 01=Jan 31=31st and TKK=car,truck,vette.
The main info I need is year and what it came out of for parts ;/The other two numbers I found on the block are C8S155281 and one that looks like 010 020 114 but Im not sure what kind of codes they are. Any help will do =)
mykey, welcome to the garage, see here for much sbc ID info, including date codes
Thanks everyone. This set is semi-apart: head, pan, pump, BH all off. I plan to get a close look at it, might take it if seller will let it go for a C. If it looks OK, I want to slap it back together as a temporary runner (at most short trips of 15mi). Would there be any part from this combo that is more desirable than other year/models? Also, who carries a reasonable gasket set to button this up, NAPA, AZ, Schucks?
'54 3100 235 3spd
