3 members (2-Ton, NJC, 1 invisible), 95 guests, and 0 robots.
Topics128,260
Posts1,058,343
Members48,485
#775355 08/27/2011 12:17 AM
Howdy all!
I'm a new guy with probably an old question. I was curious what oil other bolters are running, I have been running castrol 5w30 with BG's RF-7 additive in my 250 six. Is this a good combination or am I missing something vitally important? Just concerned about what I hear with modern oils not having friction reducers in them that older engines need.
Any help is appreciated
ergbert
ergbert
66 c10 fleetside
64 c30
ergbert #775390 08/27/2011 2:28 AM
Modern oils will be fine, you really only run into trouble if you replace the cam/lifters or are running a race type camshaft with high spring pressures. You really don't ned the addative, from what I read about it, it only increases the viscosity. Best bet would be to bump up to 10w-30 if you need a heavier oil.
Bill Burmeister
LONGBOX55 #775407 08/27/2011 3:06 AM
i use kendall 10w30, love the stuff and never had any problems
1966 Chevy C/60 Wrecker
Story in the Gallery
Pictures on Flickr
It don't rust if you run it hard enough
