1 members (Hotrod Lincoln),
76
0
Mod | | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 63 | Maybe I didn't search enough, 1hr & no matches, but here is what I've got and all I could figure out. can you provide more info on these numbers?
Block cast # 3837004 GM25
Block Ser. # Fb05H (Fint June ?? Truck)
Head cast # 3835913 GM10 ('54 235)
These might be mismatch parts, they're out of a '55 3/4ton truck with 4sp trans. Thanks
'53 BelAir 261 3spd/OD 4dr '54 3100 235 3spd '79 C30 with a '51 235-'57Bellhousing-'67SM420-14bolt dually '89 V3500 350/465/205 SRW CC One Chevy just isn't enough.
| | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 |
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | F605H (Fb05H) might decode as:
F = Flint, MI plant 6 = May (oops, 6=June) 05 = 5th day H = 3100 (and 3200, 3600, 3800) regular production engine/truck
| | | | | Joined: Jul 2010 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 63 | Thanks.
I knew I was close to having it decoded but was stumped by the 605 in the F605H stamp.
Is this a full pressure with cam, crank and rod bearing inserts, not babbitt?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks. . .
Is this a full pressure with cam, crank and rod bearing inserts, not babbitt? Yes | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | F605H (Fb05H) might decode as:
F = Flint, MI plant 6 = May 05 = 5th day H = 3100 (and 3200, 3600, 3800) regular production engine/truck That matches with what my code books says. To be a little more specific, it's a '57.
Bill Burmeister | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks, Bill, I left that pertinent information out. 1957 it is (indicated by the "H" in the engine serial number).
| | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | These might be mismatch parts You may be able to determine mismatched parts based on casting date codes. Your stamped engine serial number, 605 is the date the engine was assembled. I'm confused because I thought 6 = June. Your block casting date code should be located near the 3837004 block casting number. Example - E127. Your head casting date code is directly across from your head casting number 3835913. Example - D196. Post the date codes and maybe we can help.
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks, Tom,
I counted my fingers incorrectly (I have an imdigiment of the right hand).
I've added a correction and a note, above.
| | | | | Joined: Aug 2011 Posts: 4 New Guy | | New Guy Joined: Aug 2011 Posts: 4 | Im having the same problem... I just got a 1962 C-10 with a late year 350. I have been trying to decode it via only and I have only got so far. Casting # 3970010 and Block Stamp ID V0131TKK.I think I figured out the stamp as being V=Flint 01=Jan 31=31st and TKK=car,truck,vette. The main info I need is year and what it came out of for parts ;/The other two numbers I found on the block are C8S155281 and one that looks like 010 020 114 but Im not sure what kind of codes they are. Any help will do =) | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | mykey, welcome to the garage, see here for much sbc ID info, including date codes Bill | | | | | Joined: Jul 2010 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 63 | Thanks everyone. This set is semi-apart: head, pan, pump, BH all off. I plan to get a close look at it, might take it if seller will let it go for a C. If it looks OK, I want to slap it back together as a temporary runner (at most short trips of 15mi). Would there be any part from this combo that is more desirable than other year/models? Also, who carries a reasonable gasket set to button this up, NAPA, AZ, Schucks?
