7 members (Otto Skorzeny, Hotrod Lincoln, Slick Willy, 1955 1 Series, GrandpasJimmy, BarryP, 1 invisible),
95
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,925 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 7 New Guy | | New Guy Joined: Aug 2011 Posts: 7 | I would like to know what seals gaskets and hoses and other parts I need to get while doing my 235 overhaul to keep it compatible with the ever rising amount of corn they are trying to shove in my tank and also keep it good to go with unleaded. The main focus of this engine will be fuel economy and as much reliability as possible as its future is long hauls in an RV with some possible towing (popup or boat). It has a carter BB updraft carb on it now as far as I can tell from reports on models used and a casual glance and no room to change from updraft (though sidedraft may be an option). Please consider no tips too obvious as I am a serious newb with only maintenance experience on my modern vehicles by way of automotive expertise. The good news is I have all the time in the world to do this right. You may find some pics here.
| | | | | Joined: Apr 2011 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 181 | I have several Stovebolt sixes that are 40 to 50 years of age. I have torn them all down. I have not seen any indications that the modern day fuels have caused any significant damage. While the engine is apart I suggest you take the head into a good reputable machine shop and ask for a three angle valve grind and replace the seats with a later metalurgy that is now available. Go to www.rockerarms.com and see if they stock a fully rebuilt set of rockerarms on a refinished shaft. They do very good work. I traded with them 30 years ago in Torrance. Now they are in Anderson, CA. If you can avoid it don't shave the head. But do "Deck" the block and check all manifold surfaces. Use good high quality gaskets and I strongly recommend a copper head gasket. Good luck. I have put many miles on these engines and am a fan of them still. Normbc9 | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I have had no problems with the alcohol in the fuel with the exception of it ate up the fuel pickup hose in my weedeater. But as far as cars go, no problems. Unless I pickup another piece of rubber in my needle valve in the carburetor. which at this point I am calling a coincidence. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | If your valve seats are good I wouldn't spend the extra money to install hardened seats. Its been discussed a considerable amount in previous posts. I realize that many guys have done the change, but many have not and been driving their trucks many miles with unleaded fuel trouble free. The alcohol that is added to the fuel now days is hard on rubber. I'd recommend changing the rubber hoses in your fuel system. You should also buy a good quality carb kit and install it. You might have to tweek the timing and work with the carb adjustments when you get it on the road. Good Luck Don | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | The only problem i have had on my 54/235 is it ate the diaphragm in the fuel pump. it was a replacement with the dual action. i used the old one for 20 years and the put the dual action in and it failed after two years and that was mostly sitting ready to be put back together. i drove it 20 years before the overhaul with no problems. i also have a 1960 mga that i have had since 1968 and no problems with the gas.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Unless you're working the engine to it's limit for extended periods you'll have NO problems with unleaded gas. I'd heard of FAR more issues arising out of hardened seats being installed than not installed.
| | | | | Joined: Aug 2010 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 38 | I have suffered more than one fuel pump diaphragm failure because of what "corn fuel" does. I have also encountered some disscussion on the metal eating acid that forms from corn ffuel. | | |
