0 members (),
85
0
Mod | | | Forums66 Topics128,115 Posts1,056,291 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#77444 05/11/2007 4:49 AM | Joined: Apr 2007 Posts: 44 Member | | Member Joined: Apr 2007 Posts: 44 | Well i was in reverse,backed up a few feet- went to go to first and missed went to third, then when i tried to go back to neutrual to go to first it was hung up in third had to get out and move the 2/3 gear lever to neutral position of course had to turn off engine as it was stuck running in third- any ideas? thanks for the help Ken | | |
#77445 05/11/2007 6:18 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Usually that means that the bushings in the little shift box at the base of the steering column are worn out.
#77446 05/11/2007 6:20 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | things are worn and/or gummy in the shift box on the lower column, a very common problem with these ol trucks - open it up, clean it out, check the notched arms are crisp, have good corners, and line up right, and the pawl is a good snug fit between them - regrease it well
Bill | | |
#77447 05/12/2007 6:16 AM | Joined: Apr 2007 Posts: 44 Member | | Member Joined: Apr 2007 Posts: 44 | Thanks for the replys gentlemen, what is the correct grease type for this box Ken | | |
