1 members (Steelonsteel), 141 guests, and 1 robot.
Topics128,115
Posts1,056,289
Members48,439
Well i was in reverse,backed up a few feet- went to go to first and missed went to third, then when i tried to go back to neutrual to go to first it was hung up in third
had to get out and move the 2/3 gear lever to neutral position
of course had to turn off engine as it was stuck running in third- any ideas?
thanks for the help
Ken
Usually that means that the bushings in the little shift box at the base of the steering column are worn out.
Paint & Body Shop moderator
things are worn and/or gummy in the shift box on the lower column, a very common problem with these ol trucks - open it up, clean it out, check the notched arms are crisp, have good corners, and line up right, and the pawl is a good snug fit between them - regrease it well
Thanks for the replys gentlemen, what is the correct grease type for this box
Ken
