| | | Forums66 Topics128,054 Posts1,055,780 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 171 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 171 | Hello, I have one question again. After I have made a test drive with my truck, I noted that the clutch wanted not work in the higher gears. So I think I have to chance the old one and set in a new kit. My question is, can I chance the clutch without replace the engine? And one more: Witch clutch kit will fit for my truck? I have a 235 engine, and the truck is build 1953. Asks Wolfgang | | | | | Joined: Dec 2006 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 97 | yES ,SURE YOU CAN PUT A NEW CLUTCH WITH OUT REPLACEING THE ENGINE ..... | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Wolfgang, yes you can change the clutch without removing the engine ,if I were you I would first get a shop manual for you're truck you can get them at places like Jim Carters or Clasic of America. As for what clutch to get it depends on whats in there,you'll have to remove the old one and then get the same one ,My 52-3100 had a 9 inch and My Buddys 50 had a 10 1/2 inch so you'll have to see whats there first.Get the shop manual and it will have a complete explanation on how to get the old clutch out and how.
Good Luck Pete
| | | | | Joined: Oct 2009 Posts: 171 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 171 | Thank guys! I'll let you know how it works! wolfgang | | |
