5 members (2-Ton, Tim Canfield, Hotrod Lincoln, 52Carl, 1 invisible), 67 guests, and 2 robots.
Topics128,079
Posts1,056,309
Members48,442
#773915 08/22/2011 2:53 PM
I'm sure someone has worked through this problem. I have a small block, TH400, and a tubular cross member from CPP. I am trying to figure out how to attach the parking brake linkage. Does anyone have any ideas ? maybe some pics. thanks
I used the whole setup from a '66-72, which does not use a crossmember to mount.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
what all do you need to change out, rear cables etc. do you use the lever under the column or later type?
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Where are the frame hangers and the cable clips available. Like from a certain year range at a salvage yard maybe. Does this setup use the old style lever? Thanks
'66-72 1/2 ton GM trucks, keep the underdash lever/cable, swap everything else.
Socket Breaker
Socket Breaker
Socket Breaker
Socket Breaker
same and updated information/photos, new URL/location:
'66-'72 setup - as 64fleetside mentioned - pics, photos, layout.
-W
