6 members (MickeyP, 5 Window 9434, cmayna, 78buckshot, Samantha, 1 invisible), 94 guests, and 2 robots.
Topics128,062
Posts1,055,851
Members48,428
#7742 11/26/2003 10:27 PM
Junior Member
Junior Member
I just bought a 54-55 gmc straight 6 250 truck
(no bed) in time to store it for the winter.
I have driven it VERY little to this point.
On my way to the storage garage (8 miles) the truck began to lurch, jerk and I had very little power. It did fine for 7 + miles, inches from my destination.
The engine sounded like I was flooring the accelerator while in 2nd gear - - strained.
There was oil near the two spark plugs closest to the firewall, oil on the ground 4-6" diameter.
Within minutes, it started up fine, and I got to the storage garage.
I am very green to this truck and the older ones in general.
Where do I start?
Rear seal? A choke issue? (it was pulled half out on a 55 degree day)?
Ideas of where to start?
zan
#7743 11/27/2003 1:13 AM
you should drive the truck on the choke for as little as possible. I usually don't leave the driveway until I can push the choke all the way back in.
It could be as simple as that.
54 3100 with 235
62 flatbed dump C60 with 261
#7744 12/01/2003 5:05 PM
There's a SLIGHT possibility that coolant may be entering 1 or more cylinders while running, causing resistance during the compression stroke, making your engine "strain". Not a common occurance, but you never know.
Heavy metal worker--up to 4-inch plate.... If you can't cut it, burn it!
#7745 12/02/2003 11:00 AM
When was the truck last driven? You could have an ignition problem. You could have a coil that is overheating, for example.
Paint & Body Shop moderator
