| | | Forums66 Topics128,159 Posts1,057,029 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 239 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 239 | Pulled the heater motor. There are 3 wires coming from the motor. One wire is ground and the other two are for hot leads to the two speed motor. The under dash mount switch has two terminals on the back. The switch rotates and there 3 positions. I assume off, low speed and high speed. The switch came in a box with the truck. I hooked up the switch and it does not work. I want to buy a switch that will function with the two speed motor. Looking at the various after market truck vendor web sites leaves me confused. Are they for two speed motors? Any ideas? thanks, Larry
| | | | | Joined: Jan 2002 Posts: 2,843 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,843 | I'd expect most suppliers can supply you with a standard under dash mount 2 speed switch. The switch is different depending if you are running 6 or 12 volts.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Use a rheostat switch and connect the high speed fan wire to it. That way you'll have an infinite number of speeds instead of just two.
