5 members (52Carl, Bill Hanlon, Danielbolt, 2 invisible), 47 guests, and 4 robots.
Topics128,180
Posts1,057,163
Members48,464
Doing lots of research and have been reading all I can find relating to a T5 swap and still have some questions. I have a 55 3100 with a 235, factory 4 speed and 4:11 rear. What T5 will work the best? I have a 90 S10 with the 4.03 1st gear, 0.86 5th for a swap. Will this be ok or should I look at a 85-89 with the 3.76 1st and .72 5th or a Camaro V8/V6 to do a front shift conversion with the S10 parts?
1955 Chevy 3100
Riding in the Passing Lane
The mid 80s S-10 is very common & good. It has .072 o-drive. It has the mechanical speedo. Most 88 & all after theat had the elec. speedo drive & most had the >086 o-drive which is not good with 4.11 rear end. Look on the tag 1352-145 is the best one to use.
1972 Chevy c10 Cheyenne Super
Thanks and managed to find a pair of them, 145`s, last week. Also bought a spacer so I don`t have to trim the input shaft or retainer thus allowing an easy replace if I have to swap it out.
1955 Chevy 3100
You might want to pick up a driveshaft from a short bed mid 80's S10 to give you the front slip yoke for the t5. On my 54 conversion with a 145 t5 box to a Camaro (88) diff, the driveshaft was a perfect fit. You might get lucky......
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
