2 members (Hotrod Lincoln, Bill Hanlon), 66 guests, and 1 robot.
Topics128,049
Posts1,055,677
#77371 05/09/2007 10:34 PM
V
V Offline
I,m getting ready to put a 1965 283/PG in my 50 is there any thing I should be aware of...clearing steering box...do I need to use headers...not sure what rearend is in it now...4spd granny trans. in now...I have an S10 rear out of a 4wd,,,can I use it Thanks for any help....Virg
#77372 05/10/2007 3:17 AM
If you search here and in the hi po forum you'll find numerous threads dealing with issues around this swap.
Steering interference is definitely an issue. Moving the box out away from the frame is one approach. Some specific exhaust manifolds are said to work but I've never tested that. The rams horn manifolds I expect you have aren't likely to clear.
The S-10 year should be a workable option. The stock rear will not be.
You can buy engine and transmission crossmembers that should simplify the swap.
Make sure your brakes will stop it!
#77373 05/10/2007 11:30 PM
V
V Offline
I got the crossmembers. What is the proccess for moving the steering away from the frame, is there a search for that? Virg
#77374 05/11/2007 2:41 AM
I'd search using 'steering' and 'exhaust' and then expect to dig a bit to find details of how someone solved the problem. Most the returns will be people identifying the problem.
#77375 05/11/2007 9:01 PM
Be careful how much power you put to that S-10 rear I have an S-10 on 33" tires and I break them often. They are only a 7&1/2 inch ring gear.
I think that the ram horns will work it's what Chevy used in the Taskforce trucks. They should exit just in front of your steering box.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
