2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#77371 05/09/2007 10:34 PM | Joined: Jul 2006 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 92 | I,m getting ready to put a 1965 283/PG in my 50 is there any thing I should be aware of...clearing steering box...do I need to use headers...not sure what rearend is in it now...4spd granny trans. in now...I have an S10 rear out of a 4wd,,,can I use it Thanks for any help....Virg | | |
#77372 05/10/2007 3:17 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | If you search here and in the hi po forum you'll find numerous threads dealing with issues around this swap.
Steering interference is definitely an issue. Moving the box out away from the frame is one approach. Some specific exhaust manifolds are said to work but I've never tested that. The rams horn manifolds I expect you have aren't likely to clear.
The S-10 year should be a workable option. The stock rear will not be.
You can buy engine and transmission crossmembers that should simplify the swap.
Make sure your brakes will stop it!
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#77373 05/10/2007 11:30 PM | Joined: Jul 2006 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 92 | I got the crossmembers. What is the proccess for moving the steering away from the frame, is there a search for that? Virg | | |
#77374 05/11/2007 2:41 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I'd search using 'steering' and 'exhaust' and then expect to dig a bit to find details of how someone solved the problem. Most the returns will be people identifying the problem.
#77375 05/11/2007 9:01 PM | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Be careful how much power you put to that S-10 rear I have an S-10 on 33" tires and I break them often. They are only a 7&1/2 inch ring gear. I think that the ram horns will work it's what Chevy used in the Taskforce trucks. They should exit just in front of your steering box. | | |
