3 members (Bill Marlow, 2 invisible),
109
Mod | | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 29 New Guy | | New Guy Joined: Jan 2007 Posts: 29 | Tried searching topics... preping cab for sand blasting, removed all the bolts. Bottom hinges pull right out from cab. Upper hinges catch on the lip around the opening. Is there a certain way to twist the hinge? does it need to be open or closed? whats the trick?
Thanks, Tom
Too Many Projects, not enough time
| | | | | Joined: Jan 2007 Posts: 29 New Guy | | New Guy Joined: Jan 2007 Posts: 29 | Guess I should add I have a 52 3/4 ton
| | | | | Joined: Jan 2007 Posts: 29 New Guy | | New Guy Joined: Jan 2007 Posts: 29 | OK got them out, Just had to take a little break.
found that you need to open the hinge to clear the spring. pull out till it hits the lip on the outside edge. then close hinge and tap lightly with the palm of your hand it it will slowly come out
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Now that you have them out prior to paint open them up a little bit with a roto-file you won't scratch anything and generally make life easier with the install. | | |
