10 members (DadsFirstPickup, TUTS 59, JW51, GRNHydra, Ponchogl, GradyB, Leo, Jon G, walterhvogel, 1 invisible),
50
0
Mod | | | Forums66 Topics128,080 Posts1,055,944 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#77364 05/09/2007 4:02 PM | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | I finally have all the parts collected to start my T5 swap. I need to know about cutting off the T5 bearing retainer. I have read all the threads but I'm not sure how much to cut off. I need to use an adaptor for my 216 bell housing so do I measure the length from the adaptor plate or do I use the length of the bearing retainer from my original trans. There may be as much as 1/4" difference between these two measurements. Does this matter? I know that several of the Stovebolt family have made this swap using an adaptor, so what did you do? Thanks George | | |
#77365 05/09/2007 7:48 PM | Joined: Apr 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 275 | George, I've never done a T5 conversion but as general practice I'd make it as long as possible for max. slider support. Mock up all the clutch & other parts, see a what point it contacts anything & cut it so when everything is bolted together there will be say 1/4" of running clearance. Doug | | |
#77366 05/09/2007 8:37 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have done many T5 conversions without an adapter, and I cut 1" off the retainer and 1/4" off the input shaft. You would need to subtract the thickness of the adapter from the 1" and you may not need to cut the shaft.
See the USA in your vintage Chevrolet! My Blog | | |
#77367 05/09/2007 11:29 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | remember It's easier to cut more ... than to add back what you cut off too much of
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#77368 05/10/2007 12:31 AM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | George
Measure the length of the pilot shaft of your original transmission. Then Measure the length of the bearing retainer from the transmission mounting surface. Then Measure the thickness of the adapter plate (1/2 inch 6061 alluminum?).
What you are trying to accomplish is to get the new transmission to look like the old one as far as the engine is concerned. Take the thickness of the adapter plate in to account. If the original transmission has a bearing retainer that is 5 inches long, the T-5 should have a bearing retainer that is 5 and 1/2 inches If you are using a 1/2 inch thick adapter plate. (PLEASE NOTE THAT THE DIMENSIONS GIVEN ARE ONLY EXAMPLES AND NOT ACTUAL MEASUREMENTS) Due to the added thickness of the adapter plate, it is unlikely that you will have to extend the splines to get more clutch travel.
John | | |
#77369 05/10/2007 3:51 PM | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Thanks guys. I thought that I needed to take the thickness of the adaptor into account, but I thought I would check with those of you that have done this before. George | | |
