1 members (78buckshot),
64
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 127 | '59 235/3200 what is the correct pressure cap for this motor? 3#-4#. Thanks in advance for your time.
Jessica's TruckThe true definition of insanity: To do the same thing the same way repeatedly and expect a different result each time. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Village_Idiot, I believe they are supposed to use a 7lb. cap, o.e.m. p/n 850795, however the Jim Carter catalog lists a 4lb. cap from 1947 - 59, so your guess is as good as mine. | | | | | Joined: Jul 2010 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 127 | Am I to understand correctly that the weak link here is the heater core and if I over-pressurize the system i risk damaging the heater core? Jessica's TruckThe true definition of insanity: To do the same thing the same way repeatedly and expect a different result each time. | | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | The heater core is a concern, but some of the early-style radiators don't work well with higher-pressure caps, also. I'd consider a 7# cap to be a maximum. Every pound of pressure raises the boiling point of the coolant 3 degrees, so going from a 4# to a 7# cap only gives you 9 degrees of extra boil-over protection. Jerry
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the heater core is one of the weak links, as is the rad [especially the tank seams] - the hoses may be the weakest link, depending on how old they are .... a 59 should be able to easily handle a 7# if everything is in good condition and that's what was original
Bill | | | | | Joined: Jul 2010 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 127 | Thanks for the reply. I will try a 7#. The rad and hoses are new so no worries there. Just wanted to be sure I wasn't putting unnecessary stress on the system. Jessica's TruckThe true definition of insanity: To do the same thing the same way repeatedly and expect a different result each time. | | |
