2 members (Rmillerfly, 1 invisible), 59 guests, and 2 robots.
Topics128,050
Posts1,055,757
V
V Offline
'59 235/3200 what is the correct pressure cap for this motor? 3#-4#. Thanks in advance for your time.
Jessica's Truck
The true definition of insanity:
To do the same thing the same way repeatedly and expect a different result each time.
3B Offline
Hy Village_Idiot, I believe they are supposed to use a 7lb. cap, o.e.m. p/n 850795, however the Jim Carter catalog lists a 4lb. cap from 1947 - 59, so your guess is as good as mine.
V
V Offline
Am I to understand correctly that the weak link here is the heater core and if I over-pressurize the system i risk damaging the heater core?
Jessica's Truck
The heater core is a concern, but some of the early-style radiators don't work well with higher-pressure caps, also. I'd consider a 7# cap to be a maximum. Every pound of pressure raises the boiling point of the coolant 3 degrees, so going from a 4# to a 7# cap only gives you 9 degrees of extra boil-over protection.
the heater core is one of the weak links, as is the rad [especially the tank seams] - the hoses may be the weakest link, depending on how old they are .... a 59 should be able to easily handle a 7# if everything is in good condition and that's what was original
V
V Offline
Thanks for the reply. I will try a 7#. The rad and hoses are new so no worries there. Just wanted to be sure I wasn't putting unnecessary stress on the system.
Jessica's Truck
